clutch pedal stud size ?
Postby Power Ram Man » Sun Aug 17, 2014 7:38 pm
Anyone no what the clutch pedal stud that bolts to master cylinder size is mine is gone 7/16 seems to small 1/2 seems to big is it metric ?
92 3/4 Cummins with coverted getrag 5 speed, 4x4 PODS,3200 Gov spring,16cm housing, 4inch exhuast homemade downpipe, water meth,hx35 turbo,5 inch stainless intake with AFE filter, fuel turned up, timing bumped boost,pyro guages, Denny T fuel pin,coolertubz,piston lift pump
Power Ram Man
