NV3500??
NV3500??
Postby oldestof11 » Fri Dec 07, 2007 6:44 pm
Other than they are GM trannies, can/will they hold up to a Cummins?
Postby MUDDY » Fri Dec 07, 2007 9:54 pm
nv 3500 is a half ton and jeep trans.
doubt they'd last too long
97 D-3500 flatbed dually 385/837
93 D-350 dually
90 W-250
FOR IDAHO EVENTS WATCH
http://www.idahoturbodiesels.com
MUDDY
Postby Philip » Fri Dec 07, 2007 9:54 pm
I wouldn't hold my breath for to long about them. Here are some spec's I found. Look at the input torque rating.
Manufactured by New Venture Gear
Order code: DDC
Input torque rating: 300 ft-lb
Max GVWR: 7,200 lb
Max GCVWR: 11,000 lb
Fluid Capacity: 4.8 pints to the bottom of the fill plug
Weight (with oil): 110 lb
Mopar Manual Transmission Lubricant (PN 4761525) is the ONLY lubricant recommended for the NV3500.
Fill Plug: Front housing on passenger side
Drain Plug: Bottom of the front housing
Postby RumbleFish » Fri Dec 07, 2007 10:30 pm
300 lb-ft? I bet it'd last forever in a chevy.
Postby wannadiesel » Sat Dec 08, 2007 7:01 am
You could probably blow the countershaft right out the bottom of the case. :2cool:
Best dyno: 408/844
wannadiesel
diesel guru
Postby oldestof11 » Sat Dec 08, 2007 11:16 am
But dont they put hopped up V8's for rock crawling in front of them? The only reason why I am asking is cause they are a dime a dozen. Maybe something billet might help?
Just wondering. Trying to do something on a budget.
Postby PToombs » Sat Dec 08, 2007 12:48 pm
Jon, didn't you know? You can't use "Cummins" and "budget" in the same sentence. :shock: It's a law or something! :sunny:
It's a Good Tranny
Postby Ace » Sat Dec 08, 2007 2:50 pm
It's a good tranny for the application - just not a "Cummins" application. I like the one behind the 5.2 in my 1500. Shifts real smooth, nice gear spread. I haven't heard it has that 5th gear issue like it's big brother, either. Got 120k on it, still running great. It takes a synchromesh or motor oil, just like the Getrag.
Ace
Postby dpuckett » Sat Dec 08, 2007 6:01 pm
Sounds like it'd be good behind a stock to mild 4BT. But, since the 4BT and 6BT have the same dimensions for tranny adapting, why not go bigger? Other than cost, I guess.
DP
