by MMiller » Tue Dec 11, 2007 8:49 pm
They work perfectly fine behind a gasser with a wide rpm range to work with, and can't effectively use a OD. Everyone I've talked to that has used one behind a Cummins hates the large gear spread, and way to many rpms when running around empty.
You've also got to remember the NP435 used a smaller input shaft and output shaft then any manual dodge ever used behind the cummins. I'm sure there is a reason or two behind that.
FWIW I've used both and watched both take tons of abuse from Big Block Chevies and Big Block Mopars, but I'd never think about backing up my cummins with one. A getrag or nv4500 will be great, and if doing alot of heavy towing then a 6 speed.
Michael
