Clutch hydraulic line question
Postby 9312v » Sat Sep 19, 2015 6:02 am
Between my self and two friends we have four NV4500's. Two of them are behind Cummins, the other two are behind a 6.5 and a Vortec 5.7 Chevy. Two of them have the plastic hydro lines, the other two have the stainless steel lines. Both Cummins have Valair dual disk clutches. Both trucks with the plastic line have stiff pedals the other two have softer pedals. The one is a super duty swap and his pedal is softer than his 12 ram 2500.
So I guess my question is how stiff are all of your pedals? is anyone running the stainless line?
The part number I was given for a compatible stainless steel line is russell 694870.
9312v
Re: Clutch hydraulic line question
Postby 93cummins89 » Sat Oct 10, 2015 5:53 pm
i have a plastic all in one master slave and resivore that you dont have to bleed. south bend single disk clutch and a G360 power by cummins (duh) my pedal is id say medium at best
93cummins89
Postby 1992gen1_fan » Sun Oct 11, 2015 7:48 pm
My truck has a soft clutch pedal, even more so after I installed the new Sachs clutch and repaired and lubed the clutch fork.
I have the clutch with the plastic lines
1992gen1_fan
Postby dpuckett » Sun Nov 01, 2015 8:45 am
Stock Chrysler hydros. South Bend 13" ConFE clutch, Getrag. Pedal is firmer than any GM I have driven, but softer than most IH semis.
