Ground spool valve as part of a shift kit????
Postby flashgordon » Tue Dec 18, 2007 6:25 pm
Here is a pic of it!
http://i125.photobucket.com/albums/p58/ ... C01927.jpg
The bright part is were the valve has been ground on an angle.
Has any body installed a shift kit, that one of these valve came with the kit, or instructions told you to do this???
Flash.
flashgordon
Postby BC847 » Tue Dec 18, 2007 7:23 pm
Yup, hold on a second (or 60). . . . .
Postby BC847 » Tue Dec 18, 2007 7:28 pm
Second from the bottom/right ~ http://hometown.aol.com/gnkim/transgo3.html
As shown, it's part of the TransGo TFOD/518 kit install. I did it as part of my heap's rebuild.
Hope this helps. :)
Postby flashgordon » Tue Dec 18, 2007 8:01 pm
BC847 wrote:Second from the bottom/right ~ http://hometown.aol.com/gnkim/transgo3.html
Hope this helps. :)
Thank you!!!!!!!YOU THE MAN :thumleft: :thumleft:
Flash
flashgordon
