will 97 auto bolt up to 92 motor
Postby i11m10c2 » Sun Feb 24, 2008 11:50 pm
Ok got a 92 cummins d250 engine great, body not so good and got a chance to get 97 3500 4x4 dualy with a dead v10 could the cummins from the 92 bolt to the 97 tranny? basicly gona do a motor swap if it will bolt to the 3500 trans.
92 D250
i11m10c2
Postby Philip » Mon Feb 25, 2008 5:31 am
The V10 uses the same transmission bolt pattern so that isn't a problem. You will need the cummins to 47RE engine adapter.
I am not sure what else you will need to get the gages to work properly.
Postby i11m10c2 » Mon Feb 25, 2008 8:05 pm
So is that plate the aluminum spacer that i have on my 06 bettween the trans and motor looks to be 2in thick.
92 D250
i11m10c2
Postby Philip » Mon Feb 25, 2008 9:59 pm
between the trans and motor looks to be 2in thick.
Thats the one.
Postby Sledpuller » Tue May 27, 2008 5:35 pm
you'll need the Diesel automatic wiring harness and computer, I found out.
And..97 engine mounts.
diesel radiotaor, a/c etc. tranny lines.. I used the V-10 stuff, but wished, I didn't. PIA to adapt.
Diesel TQ conv
1999 V-10 1st Gen
www.runnadm.com
Sledpuller
Postby GO OVRIT » Wed May 28, 2008 1:53 pm
How about the valve body?
GO OVRIT
Postby CumminsPride » Wed May 28, 2008 2:25 pm
Most guys just run a full manual VB.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby Sledpuller » Wed May 28, 2008 6:12 pm
Valve body works fine.
1999 V-10 1st Gen
www.runnadm.com
Sledpuller
