a518 hunting
a518 hunting
Postby GO OVRIT » Sat May 17, 2008 9:03 pm
Every once in a while the trans in my 92 wil kick in and out of o/d. Usually between 45 and 55. The trans temp is never hot, and I just adjusted the tps maybe 3k miles ago. Any ideas?
GO OVRIT
Postby GO OVRIT » Tue May 20, 2008 6:40 pm
Nobody else's tranny ever goes in and out of overdrive?
GO OVRIT
Postby JD730 » Tue May 20, 2008 6:44 pm
TPS is the most likely cause. When they get dirty or worn out they will do that.
I got tired of dealing with mine and its completely manual now.
Mike
The "Rattle Box"
JD730
Postby dodgetkboy78 » Tue May 20, 2008 8:06 pm
Check the plug on the tranny, and put some grease on it. On one of my trucks, the plug was loose. I had to take it apart, and re-squash the terminal
dodgetkboy78
Postby skilletky » Wed May 21, 2008 1:02 pm
mine did that too, but only at wot, no matter what speed, it will scare the hell out of ya if yer doing about 95 and mash on it, and it jumps out and tries to hit third. at least it dose me.
skilletky
