Begle's Manual Valve Body
Postby mhuppertz » Sat May 31, 2008 5:22 pm
Hey Begle!
How do you like you like your manual shift valve body? Is it wonderfully harsh and brutal?
mhuppertz
Postby Begle1 » Sat May 31, 2008 5:56 pm
I like it.
I had a manual valve body in my OEM 727, and I liked that enough that I ordered one in my Suncoast A518.
I think it's fine for a daily driver.
Cops hate hearing you chirp the tires from 1st to 2nd. It's avoidable if you shift right at stall, but if you get over 2000 RPM a little bit it's unavoidable.
My truck fishtails a little bit whenever I shift in the rain. That's fun.
But it's firm. It hasn't worn anything out in the 2,500 miles I've had it. I don't put enough miles on my truck to be a very good longevity tester.
Only thing I recommend with it is a ratchet shifter. And if you get a ratchet shifter, get a reverse pattern manual valve body.
Postby mhuppertz » Sat May 31, 2008 8:06 pm
I really miss my 'Cuda with the Cheetah valve body and solid motor mounts... I had my son drive me into town today for practice. He hadn't driven my truck since the Detroit Locker, and I now have whiplash! At least with a slush box I would have the converter pillow to soften the blow!
I would really miss my manual though.... yea, I know, schizo!
mhuppertz
Postby Tmi_13 » Sun Jun 29, 2008 5:32 am
Hello, mind if i ask where did you buy the manual VB or did you install a kit to make it manual? Anyway where did you get it? I´ve been looking to make my own manual VB but i can´t find parts or VB´s anywhere.
Tmi_13
Postby Begle1 » Sun Jun 29, 2008 10:42 am
Mine came with the Suncoast transmission. It was a no-cost option.
I'd call them. 800-868-0053
Hope that you get a dude and not the dragon lady receptionist.
That said, you could probably find a cheaper one from somebody else...
Postby CumminsPride » Sun Jun 29, 2008 12:14 pm
I have a VB for sale if you need one to work over on the bench!
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby Tmi_13 » Mon Jun 30, 2008 9:14 am
Thanks, for reply. but i found transgo reprogramming kit that convert´s VB to full manual, only little over 100$.
Tmi_13
Postby CumminsPride » Mon Jun 30, 2008 11:30 am
Watch those "reprogramming kits" Some are for the re's and won't work on a rh.
CumminsPride
