3 speed auto diffs ....
Postby burnt_servo » Sat Jun 21, 2008 5:30 pm
do we have a diff section here yet ? ....
anyway .....
i maybe about to swap straight across my diffs for the higher geared ones that are in a truck with a 3 speed auto ... my truck has a 518 .....
is this a worth while swap for a auto truck with a non locking torque converter , or is this just going to make my transmision oil really hot .....
the other diffs have much lower miles on them , so i would assume they are in better shape .
'93 w250 .... stock ...
burnt_servo
Postby dpuckett » Sun Jun 22, 2008 4:09 pm
Check them out thoroughly- Make sure you wont need gears. Philip will need to verify this, but I think the guts of the LSD and bearings are the same as the others.
I think you'd be ok with a 3.07 and OD, IF you upgrade your convertor from stock to a Hughes, DTT, Goerends, etc. If you dont, you'll still be turning the same engine RPM as with 3.54s.
Where are these 3.07s located? I need to swap my dually to a SRW anyway......
Daniel
Postby burnt_servo » Sun Jun 22, 2008 5:16 pm
thanks :) ... that is kind of what i was thinking , with the converter " slipping " .
when i swap trans i think i'll do the diffs at the same time .
the diffs are in a truck at a wrecker where i work at most weekends , here in quesnel , british columbia ,
burnt_servo
