47RE to a NP205
47RE to a NP205
Postby Old-Fart-Al » Fri Aug 08, 2008 7:30 pm
Hi guys, new member and first post here.
I just bought my second 1st Gen W350 a week ago and could use a few questions answered.
The first W350 I had was a 93 with a Getrag and the newly purchased unit is a 90 with the 727, 3.07s and the Np205. I want to install a 4 spd OD with the lock-up TC and have rounded up a guy that has a 10-K mile 95 47RE and all the stuff to do the swap (tranny, adaptor, flex plate, TC, 4X4 tail-shaft housing, ect.). I've read through alot of the old posts and they have been a great help. He wants $600.00 for everything, which I believe is a heck of a deal. I'ld like to know what you all think.
Is the 47RE the best to aquire for what I want or are there better choices?
Next is, will the NP205 in the 90 mate-up to the 47RE or will I need the NP205 from a 1st Gen Getrag 4X4 (input bearing size, shaft spline count, ect.)?
Truck has 92,000 original miles, the bed looks like it was never used and the interior is like new. I'ld like to build it right and restore it to it's former glory (with a few modifications).
If you guys have any suggestions and advice, I'ld definitly appreciate it.
OFA
90 W350LE Diesel 727/3.07's 82,000 original miles. Bone Stock.
Have and need to install A518 and Air to Water Aftercooler.
Old-Fart-Al
Postby Philip » Fri Aug 08, 2008 8:49 pm
The Dodge auto's used the same small input shaft on the transfer case. So that isn't a problem there.
The probelm is a RE transmission. It is an electronic trans. You need the RH trans which is a hydrolic trans. Look at the plug going into the trans. If it is a 3 wire plug that makes it a 47RH. A 95 should be the RH model.
Postby Old-Fart-Al » Fri Aug 08, 2008 10:34 pm
Thanks Philip for the shout.
The guy says it's out of a 95 and an RE model. Probably doesn't know what it is and is just guessing. I did ask him if it had the three wire plug, he checked it and said it did.
Is the 47RH designation on the data tag or some other spot on the tranny?
Is there anything else I can check for on the unit to ensure it is the 47RH?
OFA
Old-Fart-Al
Postby Philip » Sat Aug 09, 2008 7:03 am
If it has a 3 wire plug its a 47RH. I can't remember how many wires a RE has. I am thinking its 7 or 8 on that plug. Plus its a round plug if I remember right.
There is no data tag on a Dodge trans. Its a line of numbers stamped above the pan rail on the driver side, just below the shift linkage. Unless you know someone that works at the transmission plant the numbers mean very little. Even places that supply trans parts never ask for those numbers.
Postby PToombs » Sat Aug 09, 2008 5:36 pm
10 wire plug on a RE. I just saw it on TDR last nite. ;)
Postby Old-Fart-Al » Sat Aug 09, 2008 5:55 pm
Thanks for the info guys.
I'll check with him again tonite to double check and make sure of just exactly what he's got (3 wire or 10) before I make the trip to get it.
Thanks again, have a great weekend guys.
OFA
Old-Fart-Al
Postby sdstriper » Sat Aug 09, 2008 6:01 pm
3 wire plug socket on the transmission and it's white on the RH. The 96 and up plug socket is black, and there are other identifiers on these later years such as case castings etc.
Sun Coast has an identifier pictoral, go to the Dodge diesel transmissions and scroll down to it.
http://www.suncoastconverters.com/dodge ... ducts.html
sdstriper
Postby cummins king » Mon Aug 11, 2008 7:52 pm
would any body know if a 1996 would be an re or an rh?
Joel
Never mind i found my answer.
Man this tranny stuff is hard to figuar out. I want the right stuff in my transmission but all the shops that i go to havnt a clue what will work well, so they leave it up to me to find out what i need, and I dont have a frieken clue!
I have been looking for an rh to do a swap but with no luck, so it seems like im stuck with the non lock up, so if anybody wants to throw in a few words of advice, like what converter to use and were to find a billited saft, and what ever else i need then please dont be affaid to. :)
Thanks Joel
93 4X4 auto
cummins king
Postby fergavs » Mon Aug 11, 2008 10:37 pm
I'll just sell you a full billet rh complete w/converter 8) Price might be scary to some tho :roll:
fergavs
Postby JD730 » Wed Aug 13, 2008 12:47 pm
cummins king wrote:would any body know if a 1996 would be an re or an rh?
Use the 47RE out of the 96 and use the overdrive section off your transmission to make a 47RH out of it.
Mike
The "Rattle Box"
JD730
Postby SNOOT » Wed Aug 13, 2008 3:46 pm
The RE overdrive is a much stronger unit if you can get one use it.
1993 W350
SNOOT
Postby cummins king » Wed Aug 13, 2008 7:14 pm
i have called 50 + places in the last two days and the best i could come up with is two trannys sitting in the USA. They both want 1500 for them, both are condition unknow, and shipping is 1000 to 1200 bucks.
So im going to have 2500 dallors in to the tranny before i have even rebiult it. :(
So im going to stick with the a518 unless some mirical happens.
93 4X4 auto
cummins king
Postby CumminsPride » Thu Aug 14, 2008 5:24 am
Joel, how far are you from Michigan? There is a good RE out of a 98 on craigslist.org for 600. You would still need the adapter and starter though.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby cummins king » Thu Aug 14, 2008 8:35 pm
Not far but its the time to do it,
but i thought you could only use the trannys out f the 94s to 95s, because theres a 96 tranny, localy but i thought it wouldnt work?
93 4X4 auto
cummins king
