Ok here is what I have... I tore apart two trucks this weekend...one is a 1992 D350 2x4/getrag and the other is a 1990 4x4 with a NV4500 swapped in using an Advance Adapters bell housing.
My issue...both have the same pressure plate "SACHS" (the same casting #) but the Nv4500 truck has a 12.5" clutch (LuK)
The Getrag truck looks to be OEM SACHS pressure plate and disk 13"...Now here it gets even more confusing.
The flywheel off the 1990 NV4500 truck is lighter (lots) than the 1992's....so in an effort to get this running eventually I need to know which flywheel should I use? Laying on the floor they seem to be within 1/32" of being identical on the ring gear and the surface area, maybe even closer.... help?
added note: The 1990 trucks clutch never seemed to have enough travel...disengagement was almost on the floor. Also the 1990's clutch has like 4000 miles on it, so it wasn't worn out.
I am tempted to use the new Sachs pressure plate off the 1990 truck and go buy a new Sachs Disk and install it with the 1992's heavier flywheel...but I am wondering why the MUCH lighter flywheel in the 1990....did Dodge use different ones?
