what broke?
what broke?
Postby skilletky » Tue Oct 28, 2008 3:28 pm
monday i was leaving the house, i pulled out of the driveway, then put the peddle to the floor. as soon as it built boost, something in the trans went pop and it was done. i just pulled the trans out. i pulled the converter off and tried to turn the input shaft and it will not budge. i put a pipe wrench on it and it still would not budge. any one have a clue what the problem is?
skilletky
Postby mprmn08 » Tue Oct 28, 2008 6:11 pm
my guess from that description is probably an intermediate shaft broke and is locking it up. off the top of my head i cant think of anything else that SHOULD lock it up like that. not sayin nothin else can im just slow right now.
mprmn08
Postby Philip » Tue Oct 28, 2008 8:44 pm
Blasted a pinion carrier assembly most likely. They are made of alumin.
Postby skilletky » Wed Oct 29, 2008 4:03 am
thank you for the help, no the question is, should i rebuild the thing or drop a large chunk of money on an ats setup. i am thinking ats.
skilletky
Postby mprmn08 » Wed Oct 29, 2008 10:02 am
oh ya, good one Philip, i didnt think of that.
honestly i would just take it someone and rebuild it. i wouldnt waste all the money on an ats unless you plan on throwing down some serious numbers with truck.
mprmn08
Postby mprmn08 » Wed Oct 29, 2008 10:07 am
Oh ya, good one Philip. I didnt think of that.
Honestly, i wouldnt waste the money buying an ATS. I would just take it to a guy that knows mopar transmissions good. Unless you plan on puttin down some serious HP numbers with the truck (and be realistic) then i wouldnt bother wasteing the money on ats.
mprmn08
Postby Philip » Mon Nov 03, 2008 10:02 pm
Well at the stage your at right now. I would find something with a lockup converter. A 47RH is the model your looking for.
The rebuild prices will run almost the same between the two trans. If your going to rebuild a trans. Get one with a lockup converter to rebuild.
Postby skilletky » Tue Nov 04, 2008 12:17 pm
i have doing some thinking and searching, and i think i have decided to get a suncoast set up with billit shafts and what not. i was talking with the guy from ats, and asked him about a 47rh and he said i would need a stand alone controller and it would be a lot more expensive. but i dont know much about automatics or the difference in the models.
skilletky
Postby Philip » Tue Nov 04, 2008 9:53 pm
You do not need a stand alone controller for a 47RH. It is a hydrolic trans just like your 518. You can use your orginal wire for the OD control and then there are a couple of ways to controll lockup of the converter.
You would need a 2nd gen engine adapter and starter for the 47RH trans. The converter is longer than a nonlockup converter.
If the guy at ATS doesn't know a 47RH that then he should be fired.
Postby skilletky » Wed Nov 05, 2008 12:02 pm
i think the guy i talked to was in a hurry to get off the phone. he was really unhelpful and pretty much much pissed me off, so i decided to go to suncoast. any way, i i should have my new trans and converter and all that in a few weeks. i thank yall for the help. now maybe i can put the truck on a dyno and put down a decent time at the track.
skilletky
Postby Philip » Wed Nov 05, 2008 10:05 pm
I bet he realized you were not going to buy a 5K trans from him and didn't want to work to get your money. :lol: :lol:
Postby skilletky » Thu Nov 06, 2008 5:10 am
lol, i was planning on dropping about 6k on an ats trans, but now the guys at suncoast can have my money, but it aint like i am the only one in the world buying a trans from them.
skilletky
