nv5600 conversion?
nv5600 conversion?
Postby railhor5.9 » Wed Nov 19, 2008 5:29 pm
just bought a nv5600 for $100 bucks cause 3rd is out, it just grinds when you try an put it in. syncro??? i wana do the conversion i have the motor plate, flywheel, and a good clutch oh and a drive shaft to cut the slip yoke out of... am i missing anything???? hydros??? can i just use the getrag master and the nv5600 hose and slave??? same shifter hole as the nv4500? sry so many questions
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby Philip » Wed Nov 19, 2008 9:59 pm
Send TXS a pm and have him stop in. He has a NV5600 in his truck.
Postby KTA » Thu Nov 20, 2008 6:39 am
You will need the spacer for the starter to work with the NV5600 flywheel.
Postby txs » Tue Nov 25, 2008 8:45 am
Do not use the slave cylinder from the donor truck, use a second gen, 96 or so, the 1st gen master has a larger diameter or the 3rd gen slave is smaller and you over travel the pressure plate with the early master with 3rd gen slave. Also the ends on the pressure line
changed and you will need a longer line. Whether you need the starter spacer depends on whether the flywheel is the true 13" clutch or the 12 1/4". The 13" clutch has a bigger bolt pattern and the pressure plate mounting holes line up on the starter ring gear flywheel parting line when held up to the 12 1/4" wheel. They moved the ring gear to the front of the flywheel on the 13" so there would be enough meat at the back of the flywheel to tap holes for the pressure plate mounting bolts.
The shifter hole in the floorboard hump for the 5600 is 5 or 6" farther back than the getrag. You will need the starter also, bolt pattern changed between 1st and 2nd gen.
txs
Postby KTA » Tue Nov 25, 2008 10:23 am
I don't think you need the starter. I used the 1st gen starter with the 6spd starter spacer when I put a 6spd flywheel in my truck.
Postby railhor5.9 » Tue Dec 09, 2008 6:40 am
i have a g56 slave,, can i make that work with my 1st gen master? i need the starter stock wont line up at all spacer or not :cry:
railhor5.9
Postby txs » Tue Dec 09, 2008 7:11 am
I got my 2nd gen starter from db electric on ebay, was just over 100$ for nib. That was 5 years ago or so, don't know what the pricing is like now. If you use 2nd gen flywheel housing you need 2nd gen starter. I would recomend the second gen slave also, 3rd gen from nv5600 will fit but as in previous post you over travel the pressure plate. Not sure about the g56 slave.
txs
Postby railhor5.9 » Tue Dec 09, 2008 11:28 am
will it over travel even with a nv5600 clutch and pressure plate?
railhor5.9
