Getrag bearings
Getrag bearings
Postby bgilbert » Sun Dec 14, 2008 4:58 pm
Matt and I just went through another getrag, a 'customers' 8) tranny. Within the Zbag.com bearing kit there was a new addition, instead of only Koyo bearings, there were NSK bearings, along with a single Koyo bearing. Both made in Japan though. Maybe just a new name on the same bearing?
Plus we found made in Germany bearings in the tranny. I was thinking Koyo was the only bearing available or made.
The rebuild went well and back together pretty easily. It was a 300k mile getrag with at least one 'rebuild'. It had one of two blocker rings replaced, and a couple of the synchro rings were replaced at one time as well. The hard parts looked excellent but the synchro rings were SHOT.
Bill Gilbert
Postby Ace » Sun Dec 14, 2008 5:38 pm
I think the syncros always seem to wear faster is people running motor oil in them. I know that was the OEM spec'd fluid at the time, but that was also before good syncromesh fluids were widely available.
Postby dpuckett » Sun Dec 14, 2008 6:05 pm
The 2 trannies I did this spring were the NSK bearings, from ZBAG as well. Seems to have held up so far, though mine only has about 6K on it.
Daniel
Postby oldcool90 » Sun Dec 14, 2008 6:40 pm
Ace wrote:I think the syncros always seem to wear faster is people running motor oil in them. I know that was the OEM spec'd fluid at the time, but that was also before good syncromesh fluids were widely available.
This tranny had gear lube 80/90 run in it most of it's life.
oldcool90
Postby Ace » Mon Dec 15, 2008 8:24 am
Gear lube would be even worse for the synchros than motor oil, not to mention starving the bearings.
Postby Renigade » Fri Dec 19, 2008 6:29 am
I am fixing to service my Getrag tranny what type of oil do you recommend for it.
1993 1st gen BHAF -Smoke screw 2.5 turns, star wheel 2.5 turns. Fuel screw 1.25 turns, fuel pin ground.
Renigade
Postby bgilbert » Fri Dec 19, 2008 12:15 pm
Renigade wrote:I am fixing to service my Getrag tranny what type of oil do you recommend for it.
Right after rebuild, I suggest using an inexpensive 5w30 or 10w30 engine oil for breakin. Drain that after 200-500 miles and replace with 5w30 synthetic engine oil.
Postby Ace » Fri Dec 19, 2008 12:20 pm
If you want the syncros to last, use a synchromesh fluid.
Postby GLHS » Fri Dec 19, 2008 2:43 pm
What Ace said or some Redline MTL.
Shifts smoother, faster and is quieter than 5w30, 10w30 and 10w40 synthetics that I have used.
GLHS
Postby dpuckett » Sat Dec 20, 2008 10:33 am
bgilbert wrote:Right after rebuild, I suggest using an inexpensive 5w30 or 10w30 engine oil for breakin......
so, 5000mi is a little too long for break-in? :lol:
Return to Transmission
