torque specs
torque specs
Postby skilletky » Fri Jan 16, 2009 2:28 pm
any one have the torque specs for the flexplate to the crank, bell housing bolts, and the torque converter bolts?
skilletky
Postby KTA » Fri Jan 16, 2009 2:43 pm
Flywheel 101 ft-lb
Transmission to engine 30 ft-lb
Torque converter mounting 35-ft-lb
Postby skilletky » Sat Jan 17, 2009 1:52 pm
thank you. another quick question, i got a billet flywheel and i am about to put it on, but i don't know if i have to use the spacer from the original fly wheel? a quick answer would be very very very appreciated, trying to beat the cold and don;t want to run outta daylight. :cry:
skilletky
Postby KTA » Sun Jan 18, 2009 6:19 pm
I don't know about any spacers. The ATS billet flywheels I have installed didn't use one, only the crank bolts.
Postby BC847 » Sun Jan 18, 2009 8:00 pm
Are the Flywheel and Flexplate to crankshaft bolt torque the same?
Postby Richie O » Mon Jan 19, 2009 10:52 am
My 89 factory service man only lists the flywheel torque. I would assume flex would be the same as it is same diameter bolt.
