Torque!
Torque!
Postby Okie Smokie » Fri Jan 16, 2009 5:34 pm
Alright guys, I have made some engine performance enhancements 8) and I am driving right thru a 450/900 organic/kevlar clutch. :roll: I know which clutch I am going to use (550/1100 ceramic), ;-) but I have concerns about my stock getrag. How much torque are they rated for and how much have you seen them handle. I have been told to move to the NV4500, so I am also curious what it can handle and if it will be worth the money. I don't know exactly how much power I will be making yet. Kinda hard to dyno when the clutch won't hold. I haven't even turned on the propane and methanol yet. :shock:
'93 W250 Extended Cab, P7100, F1 Spartan, Extra Air, Tim's cooler tubes
'92 D250 Reg Cab, Flat bed, 5 speed, Bone stock
'91 D250 Reg Cab, Auto, Bone stock
Okie Smokie
Postby gear jammer 91" » Fri Jan 16, 2009 8:09 pm
the "360" in getrag 360, stands for it torque rating of 360lb. That being said there are people out there putting 1000lb of torque through them. I wouldn't worry about the trannie until it blows, but that's just me.
01 LB7
gear jammer 91"
Postby mprmn08 » Sat Jan 17, 2009 12:25 pm
i agree with gearjammer
mprmn08
Postby Okie Smokie » Sat Jan 17, 2009 6:00 pm
Thanks guys.
Are there any benefits or drawbacks to the NV4500? Does it have a higher torque rating?
Okie Smokie
Postby gear jammer 91" » Sun Jan 18, 2009 11:15 am
The nv4500 is a stronger trannie. I don't know it's torque rating but it is higher. If I had one laying around I would put it in, but for me it's not worth the money until the old getrag actually starts to give me problems. The only issue I know of with the nv4500's is with 5th gear. I believe it's a lock nut that will back off and cause issues.
01 LB7
gear jammer 91"
