205 adapters
205 adapters
Postby Raymo » Sat Feb 07, 2009 5:35 pm
So I have a four wheel drive 4500 comming which means my divorced transfercase idea isnt going to work in my Chevy conversion. My question is can I take an adaptor from a 23 spline 205 and put it on a 29? I found a cheap 23 spline 205 and want to get a 29 input for it. Are the bearings larger on the 29's? If so thats not a problem. Thanks for any input!
'94 Chevy 3500-HD cab and chassis- IC Cummins, Getrag, NP205. 60 front, 80 rear- 4.10's.
Raymo
Postby Raymo » Sat Feb 07, 2009 6:06 pm
Well I figured out I will need to put in a larger bearing... no biggie. But will the adapter fit from the 23?
Raymo
Postby bgilbert » Sun Feb 08, 2009 10:07 am
The adaptor and the case will need to be machined for the larger bearing and input.
Bill Gilbert
bgilbert
Postby Raymo » Sun Feb 08, 2009 11:43 am
sweet thanks, simple 'nuff... now I gotta find the input shaft lol
Raymo
Postby nooblet » Thu Feb 12, 2009 1:58 am
There are several different bolt patterned 205's in addition to the larger bearings. Make sure the other 205 is the correct bolt pattern.
Chris
nooblet
