by dpuckett » Thu Oct 22, 2009 1:48 pm
I would say since you are draining about half the fluid, refill with what you took out. Unless ATFs can mix and match.
I wouldnt put any additives in the tranny. Most additives (beyond fuel lube) are snake oils, or band-aids to bypass a real issue.
Dan
