Ok, so now I have a shudder between 10-15 mph. I am guessing the u-joints rather than the clutch or rear-end because it happens only at 10-15 mph, not just around corners but on the straight aways, not just in 2nd but 3rd also, and no clutch slippage in any gear. Do you think I am right?
What is the best kind to get? I also have some play in the rear-end, about 1/16th of a turn. It is really noticeable when I am shifting and coasting then go to speed up.
Need some info here. Whats the best u-joint to get, how do I fix the play in the rear-end, and if I get in the rear-end, could I put in 3.73's or 3.55's for more mpg's? I know my right foot is connected to the mpg's but will going up in ratio help too? I plan on getting wider tires (265/75 R16's) and pulling at the fair here.
Thanks for any input!
