Multi issue...charging..A/C...OD....all the sudden...
Postby 12vsuburban » Mon Aug 19, 2013 10:35 am
1992 350 Auto...all was OK...then went to leave one morning and the AC would not turn on(no compressor engaging, blower fan works)...then later that day it started down shifting from overdrive on a 3 hour trip...after a long frustrsting trip of downshifting erratically I noticed the lights were a bit dim...sure enough its not charging...11.xx volts while running. Alternator is less than a year old.....
Im suspecting maybe the ECM harness plug...will check that tonight...
Any thoughts?
Hans
'92 one ton,auto, 250k,flatbed,original paint: WH1C turbo from a '94(12/56), BHAF, 4" exh from firewall back, fuel screw to the collar, turned stock pin
12vsuburban
Re: Multi issue...charging..A/C...OD....all the sudden...
Postby ellis93 » Mon Aug 19, 2013 10:40 am
Crank sensor took a dump on you most likely,if it doesn't function properly the computer doesn't know the engine is running and won't turn on those accessories. its been my experience that Usually the od shouldn't function at all,so you symptom there is weird :?
Postby RumbleFish » Mon Aug 19, 2013 11:27 am
x2. Check the gap before you buy a new one.
Postby RCCUMMINS89 » Mon Aug 19, 2013 11:48 am
Check the gap and give it a little bit of a tap to see if it anything changes.
Return to Electrical
