Key STUCK in my steering column 1992 Dodge 3500
Postby barberjd » Sat Nov 16, 2013 9:08 am
Hello all!
I have recently purchased a 1992 Dodge 3500 2wd ext cab cummins AUTO. The truck has about 250k miles on it but runs PERFECT... however, I have many of the plagued issues that are most common with these trucks and I find this forum very helpful.
Problem:
The key is stuck into the column and I cannot get it to release. I am fearful that I am going to break the column if I try to much harder... Does anyone have or heard of a solution to this problem?
I should probably call a lock smith but what is the fun in that?
Here is the truck as well as some others that I purchased at the same time, from the same owner... and YES, the old 1969 Dodge D200 Camper Special, as well as, the 1970 Dodge D100 will be receiving 12v Cummins engines with NV4500 mated to np205, therefore I will be asking you guys a lot of questions!
Thanks, Joshua
barberjd
smoke screw?
Re: Key STUCK in my steering column 1992 Dodge 3500
Postby BC847 » Sat Nov 16, 2013 4:09 pm
Welcome to our forums, Joshua. 8)
Assuming yours is a Tilt-Wheel, this may be of help in taking things apart to get the thing fixed: http://www.dieseltruckresource.com/dev/ ... p?t=241339
If yours is a NON Tilt-Wheel, this may be of help: http://www.dieseltruckresource.com/dev/ ... 12883.html
Hope this helps. :)
Postby ellis93 » Sat Nov 16, 2013 4:22 pm
Welcome.....wish I could help :?
Postby barberjd » Sat Nov 16, 2013 8:43 pm
Thanks BC847!! I knew you guys were the right ones to ask!!
barberjd
smoke screw?
Postby barberjd » Thu Dec 12, 2013 5:24 pm
Just an update, I picked up this 1991 Cummins auto with 87k original miles for my 1970 d100. Image
barberjd
smoke screw?
Postby dazedandconfused » Thu Dec 12, 2013 5:40 pm
Welcome to the site. You collect projects like me it seems.
Postby sloppy2nds000 » Tue Jan 28, 2014 5:04 am
just leave it in there, you wont lose it that way. mine is stuck as well, hasnt come out in over 8 years. havent lost that key yet!
by the way i want a crew cab like that ole blue you got there. can you help me find one?
91 w250 a518 regular cab plow truck, bone stock, just over 100k, 1 ton front springs and air bags in the rear
94.5 f350 crew cab long bed powerstroke, 100hp beans injectors, solid state chip with 6 pos switch, adrenaline HPOP, about to turn 300k, summer work truck.
1970 bmw 2002, inka orange
1987 vw golf gti, 2.0l conversion
1994 bmw 525i
sloppy2nds000
Return to Electrical
