89 d-350 wiring diagrams
Postby Ryker Carruthers » Tue Jul 07, 2015 4:07 am
I can't seem to find the earlier wiring diagrams on here, just the ones for 93. Recently I found an 89 d-350 srw, auto truck with cruise control. The wiring is a mess in it. The guy quit driving it because wires started smoking under the dash. There is a constant heavy draw on the battery. I disconnected everything, ran a hot wire to the fss, and arced the solenoid, it barely cranks over and the ground cable gets HOT. Bad ground? Junk starter?
Thanks
Ryker Carruthers
92 W250 g360 3.55's
Ryker Carruthers
Re: 89 d-350 wiring diagrams
Postby 93cummins89 » Fri Jul 10, 2015 1:19 pm
defiantly want to get ur alternator and started checked. as far a a manual go to rock auto and in the literature/manual for your specific make and model see if the have a bishko book on CDrom its a PDF pop it in your PC and go
93cummins89
Return to Electrical
