Starter Draw Question
Postby theoldmanW350 » Tue Oct 13, 2015 2:18 pm
Hello all, I'm getting close to running a starter draw test on my pick up. I of course need to disable it from starting to perform the test. Disconnect fuse? I've had no luck searching here or CF. I feel as though It isn't a big process. Thanks!
1990 W350. Getrag overfilled. Stock fuel. Stock turbo. M2 fuel pin. Hungry Diesel HVLP lift pump, 2nd gen IC w/ 3" Pusher Intake. Air bag set-up, onboard air. BD exhaust brake. Almost all 4" exhaust. Autometer's. Upgrades as money allows.
theoldmanW350
Re: Starter Draw Question
Postby PToombs » Tue Oct 13, 2015 4:16 pm
Remove the wire from the shut off solenoid is probably the easiest way. Or put a bungee cord on the manual lever to the "off" position.
Postby theoldmanW350 » Wed Oct 14, 2015 2:01 pm
aha! the shut off solenoid crossed my mind. ok thanks.
theoldmanW350
Return to Electrical
