gauge flickering
gauge flickering
Postby (92)cummins » Sun Oct 23, 2011 6:58 pm
When ever i start my truck up and drive it the voltage gauge and temp gauge flicker, then when i hit the blinker they flick from one side to the other in the rythm of the blinker and im lost at what could be causing this
92 w350 srw flatbed
1985 D350 crew cab diesel conversion in progress
79 w200 power wagon
93 D350 drw 5spd getrag 4 door donor
90 D350 auto(fried) flatbed
93 D250 auto
(92)cummins
Re: gauge flickering
Postby collegekid » Mon Oct 24, 2011 5:25 pm
mine used to do that, reset my crankshaft sensor and they went away and quit doing it
collegekid
Postby (92)cummins » Mon Oct 24, 2011 6:45 pm
Are you talking about the crank position sensor and if so how do you reset it
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Postby PToombs » Tue Oct 25, 2011 5:37 pm
It should be .050 from the balancer. Just loosen the bolts and it slides up and down a little.
Postby (92)cummins » Tue Oct 25, 2011 6:49 pm
Ok I'll try that when I get around to it
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Return to Electrical
