dodge dealer installed tachometer information
Postby stillsmokin » Sun Mar 11, 2012 9:57 pm
Has anybody ever seen an instruction sheet that dodge would have included with the add on tachometer? Most of the accessory items we installed at dealers had a piece of paper that laid out where holes were supposed to be, etc.
Just curious, somebody on one of the forums probably has a NOS one out there with the install sheet. It could be scanned into a pdf and lend itself to the greater good.
92 W250LE REG CAB, SLED PULLER, S400
93 W350LE EXT CAB, dually, 5 speed
stillsmokin
Re: dodge dealer installed tachometer information
Postby Mark Nixon » Wed Mar 14, 2012 8:03 am
Why don't you just come down and take a template off the truck it was removed from?
Postby stillsmokin » Wed Mar 14, 2012 7:57 pm
That isn't entirely what I am wanting.
stillsmokin
Postby bmoeller » Sat Mar 24, 2012 7:31 am
Hell, flip the gauge pod upside down and make a template yourself. Place it on dash where it looks good to you.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby stillsmokin » Tue May 01, 2012 9:19 pm
FWIW, I wanted the sheet to see if the tach was supposed to be on one side of the dash or the other. They are typically mounted left of the driver. However, the 92-93 tach harness is long enough to fit a right hand side of dash installation but, I've only seen one or 2 done that way. After I installed it, I decided it was more functional in my eyes to be right of the driver.
stillsmokin
