Alternator options
Alternator options
Postby Eric_M » Fri May 25, 2012 10:35 am
Is there an option or an alternator that will bolt in that is internally regulated? Is it worth looking into?
Currently the previous owner of mine put one on there and I was told it was internally regulated? and the firewall regulator is unpluged.
The problem is right now the alternator is one rib to small on the pully so it is eating the edge of the belt... not the end of the world from what I can tell.
Just looking into options for parts to keep an eye out for.
Thanks!
91 D350 5spd stock a little rough around the edges and needing some work but it should drag my 87 4runner around great!
Eric_M
Re: Alternator options
Postby ellis93 » Fri May 25, 2012 2:41 pm
Pic of current alt?
Might be able to get an alt pulley from the correct alt and have it work on your current one. Some folks miss things like that.
Postby Eric_M » Fri May 25, 2012 8:47 pm
ellis93 wrote:Pic of current alt?
I will get a picture of it tomorrow and will have to figure out how to post it.
Eric_M
Postby Tacoclaw » Sun May 27, 2012 4:09 am
You could probably just pull the pulley off there and put the right one one. That oughta get it to quit eating belt, if you can find another pulley.
Postby Eric_M » Tue May 29, 2012 8:46 am
Dang forgot to get a picture this weekend.... Spent all the time under it and no pictures of the engine/alt.
I will see what I can do tonight.
If I had the correct one I would look into swaping but at this point I dont have any extra parts. I might have to start looking for one.
Eric_M
Postby Eric_M » Wed May 30, 2012 8:57 am
Here is what is currently installed. I dont know anything about it. Right now the regulator on the firewall is disconected. I will know more when I am able to start it up later this week and check to see if it is actually charging or not.
Sorry I dont know how else to do the pictures :x
Eric_M
Postby dazedandconfused » Wed May 30, 2012 9:15 am
That looks like a newer GM alternator like whats on my vortec 350.
Postby Eric_M » Wed May 30, 2012 9:44 am
dazedandconfused wrote:That looks like a newer GM alternator like whats on my vortec 350.
Is that good or bad???
I dont have any idea on what it is or anything. Its what was on the truck when I purchased it..... Now I am just trying to get everythinig figured out and decide if its good or bad, keep it or get rid of it sorta thing.
Eric_M
Postby ellis93 » Wed May 30, 2012 9:53 am
I'd leave it if it charges. Far as what it is,its chrysler,just not sure from what.
Postby Eric_M » Wed May 30, 2012 10:13 am
ellis93 wrote:I'd leave it if it charges. Far as what it is,its chrysler,just not sure from what.
I should know by friday if its charging or not.
I am thinking just trim the belt to fit, so remove one groove from it. its already well damaged at this point. And keep an eye out for the correct pully with enough room for the belt.
Sorry the pictures are not any better. Phone dosnt like dark close pictures.
Eric_M
Postby Eric_M » Sun Jun 03, 2012 8:24 pm
So its charging nicely. I am thinking its a 2nd gen alternator.
Just means I need to find the right pulley for it.
Eric_M
Postby Eric_M » Mon Jun 11, 2012 3:29 pm
Any one know of a good place to find the right pulley? and will any pulley with the correct number of ribs work?
Looking at replacing the belt at the same time and get it all back up to good. and probably the idler pulley at the same time.
Eric_M
Postby CUMMINSDODGEMAN3 » Fri Jun 29, 2012 5:56 am
My 24v had a alt that looked like that...
Team Green's old hauler 05 3500 CTD 4x4 6sp 8in rize industries lift, 37 Toyo M/T's, Smarty, Edge Att, AFE intake, ATS manifold Borg Warner turbo, 5in SS MBRP
90 W350 CTD SRW big pump, big turbo, lots of fuel, 47RH billet suncoast triple disc and 20's
93 D250 CTD ext cab pump work, POD's
CUMMINSDODGEMAN3
