tach
tach
Postby (92)cummins » Mon Sep 24, 2012 5:51 pm
my tach quit working and i absolutly cant figure out whats wrong with it do the crank sensors tend to go out?
92 w350 srw flatbed
1985 D350 crew cab diesel conversion in progress
79 w200 power wagon
93 D350 drw 5spd getrag 4 door donor
90 D350 auto(fried) flatbed
93 D250 auto
(92)cummins
Re: tach
Postby PToombs » Tue Sep 25, 2012 5:38 pm
Sometimes the plug gets corroded at the front of the head. It could be out of adjustment, it should be .050 from the balancer.
Re: tach
Postby bmoeller » Thu Sep 27, 2012 6:02 am
PToombs wrote:It could be out of adjustment, it should be .050 from the balancer.
IIRC, you are supposed to use a brass feeler gauge to set it as well.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Re: tach
Postby oldestof11 » Thu Sep 27, 2012 7:43 am
What's the difference between a regular set and brass other than what they are made of?
Re: tach
Postby (92)cummins » Thu Sep 27, 2012 9:52 am
well its not out of adjustment, and my fan belt ripped off wiring when it exploded so i dont have a plug anymore and i cleaned all the connections from the tach to the sensor and still nothing
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: tach
Postby PToombs » Thu Sep 27, 2012 4:58 pm
Maybe 1 of the wires where the plug used to be is corroded or came apart? Do you have AC or cruise? If they don't work the sensor may be bad, it lets the PCM know the engine is running and lets them turn on. OD also if you have an automatic.
Re: tach
Postby (92)cummins » Thu Sep 27, 2012 7:46 pm
haha i didnt have working AC or cruise to start with, ill take a closer look at the wires and maybe replace the sensor
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: tach
Postby captjackm » Thu Mar 20, 2014 3:33 pm
question:
what if you have no charging, no A/C, but have cruise and overdrive? Charging and A/c do work intermittently, but I cannot find out what it takes to make them work.
1993 Dodge W250
I have good grounds, wire resistance in specs, no damage, damn near completely stock other than extra lights, clean connections everywhere.
CPS or computer? Or??
(2) 1993 Dodge W250 4x4's, diesels, one automatic, one stick. One white, one red.
captjackm
