Thermocouple compatibility pyrometer
Postby IH4life » Mon Mar 21, 2016 3:08 pm
Im currently switching from westach gauges to autometer gauges and wondering if I can reuse the Thermocouple from the old pyrometer? The westach is a nice cable that's steal braided K type and also seized into the manifold and for the life of me cannot remove. neither web site of each manufacture specifies any information. I was thinking I could measure the resistance in the cable/Thermocouple for some base line info and make some phone calls?
73 IH crewcab with 89 cummins. BW 62SXE, head studs, 4" back, 3200 spring, M & H spacer and #4 pin, BHAF, 2nd gen I/C and radiator, NV4500, South Bend single disc, 4.10s, 37s, Pyro & boost gauges, pump tweak, 29 spline 205.
IH4life
Re: Thermocouple compatibility pyrometer
Postby BILTIT » Mon Mar 21, 2016 3:12 pm
Yes you should be able to use whichever, they are most likely both 'K' type thermocouples (yellow and red wires).
You want to measure millivolts on a thermocouple not resistance. They are just two different material wires welded together so resistance will be close to zero.
Derek B.
BILTIT
Postby IH4life » Mon Mar 21, 2016 3:40 pm
Thanks! yeah im really lacking in the electronic/multimeter department! I had to edit my post cause I realized the probe that came with the autometer gauge (used) is short and stubby and not likely a K type but that's all im really seeing on their website anyways(K Type). And yes they are both read and yellow wire! Phew!
IH4life
Postby IH4life » Mon Mar 21, 2016 3:50 pm
http://www.teamrip.com/masc1thermocoupleinstall.htm
incase this is ever searched again!
IH4life
