Early '89 Thermistor replacement
Re: Early '89 Thermistor replacement
Postby jesehowells » Wed Oct 23, 2013 5:47 pm
no i have no wait to start light or nor do i hear the relay click and i have two 1st gens one is a 93 and the other is a 89 the 89 only has a air temp senor no coolant temp senor i have pulled both out the look the same but the 89 is longer and the 93 is shorter but same plug end. On that note i have tryed called the dodge dealer they cant give me any idea i have caled local parts dealers no help i wounder if cummins would now what iam talking about is that where you got yours from?
jesehowells
Postby cmann250 » Wed Oct 23, 2013 6:37 pm
If you're confident you have late model grid heater controls, the sensor should be bad. If you have early model heaters, they won't preheat until it's 15*.
I have the early model heaters, so my '89 starts better at 14* than it does it at 34*.
