Speedo dead
Postby MBergman » Mon Mar 31, 2008 9:13 am
If you guys saw how pitiful the speedometer pinion section was in the catalog is, you'd all understand. The book has a better chart, but not by much.
If your truck had LT235/85R16 tires originally, the adapter is a 4428549, 1.3846:1 ratio. List price $99.10. You may want to use a 4428962, 1.4:1 ratio for the taller tire. Thats the closest you will get. It lists for $83.45, and its discontinued with only two left in the system.
Marc
1993 D250 Club Cab, 5-speed, 3200rpm gov spring, Southbend 13" clutch, HX35 gated 14cm, BHAF, no muffler.
1983 D350 Crew Cab shortbed 360; 1991 W250 360 5-speed; 2004 3500 Quad Cab 4x4 Cummins
MBergman
Postby nooblet » Mon Mar 31, 2008 11:07 am
MBergman wrote:If you guys saw how pitiful the speedometer pinion section was in the catalog is, you'd all understand. The book has a better chart, but not by much.
Marc
Awesome, thats exactly what I was looking for!
I understand that the computer/book is probably confusing, it just made me mad that they were being less than willing to help. I expect that when I go to vatozone, but not at the dealership. Not to mention the "manager" talking to customers like that :roll:
I've purchased a ton of stuff from there, they could be much nicer and more helpful than they were.
Chris
P.S. I know Corinth is pretty far, but were you going to try to make the Diesel Dyno in Buda on the 12-13th? It would be cool to see another first gen. there, something tells me I will be the only one :evil:
nooblet
