main cab power wire?
Postby manyholes » Sat Oct 15, 2011 11:41 am
is there a main power wire that feeds the dash and fuse box? my pyro goes nuts when i turn my headlights on but if i play with the heater and fan speed i can either get it to stop going nuts or it just pins itself straight down. checked fuseable links and all seemed to check out ok. headlights have been giving me some grief, mostly flickering on high beams but only on lower revs, charging system has been replaced, battery, alternator, voltage regulator. checks out at 14 volts when running. any ideas where to start? the pyro is tied into power windows fuse block because the '90 doesnt have p/w's so it was an open power source.
thanks guys
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Re: main cab power wire?
Postby Gots_a_sol » Sat Oct 15, 2011 4:02 pm
poor grounds sound like your problem
-Joe
Gots_a_sol
Postby manyholes » Sat Oct 15, 2011 6:32 pm
the grounds under the hood are good, where are the grounds in the cab?? i cleaned up the batter posts even though its a new batt, engine ground, body ground by battery, voltage reg tight into sheet metal. basically anything i could find under the hood, i cleaned and tightend.
manyholes
Postby PToombs » Sun Oct 16, 2011 5:02 pm
Ground strap from the back of the head to the firewall? The dash ground is right of the steering column on a metal bracket.
Postby collegekid » Sun Oct 16, 2011 8:21 pm
what kinda pyro is it?
collegekid
Postby manyholes » Mon Oct 17, 2011 12:18 pm
its a swing gauge autometer phantom 2 i believe
manyholes
Postby manyholes » Mon Oct 17, 2011 12:21 pm
hey toombs il check the colum ground, thanks for the input guys
manyholes
