Wiring Harness question
Postby NOT_A_BLAZER » Wed Feb 15, 2012 8:55 pm
I am planning a cab swap this coming spring for my '91. The "new" cab was from a '87 gasser. I want to have everything inside the cab ready to go when I do the cab swap,to minimize down time on the truck,so I was looking for a in-cab wiring harness to wire up the cab and have it ready to go. The problem is my truck is a '91 non-intercooled model,and finding a donor is proving to be difficult. I was wondering if I could use a '90 harness,as long as I use the steering column that goes with it? Would it mate up with the underhood harness alright?
Nick
1991 D250 (5.9 CTD/727/D70) all stock (for the moment)
1987 D100 (225 Slant/904/8.25) future body donor for the '91
1979 Ramcharger (318/727/NP208/D44/9.25) Project Truck
NOT_A_BLAZER
Re: Wiring Harness question
Postby Mark Nixon » Fri Feb 17, 2012 11:26 am
Yes, the 1990 dash harness is compatible to the 1991 (Intercooled AND Non-Intercooled) engine harness.
If you'd rather retain the '91 column, I do have a couple of decent dash harnesses for a '91, still in trucks.
