Just Wondering If You Ever Figured Out What The Issue Was?...2 Days Ago I Replaced My Headlight Switch, Headlight Switch Connector, Ran A New Blk/Ylw From The Connector To The Harness, & A New Pnk/Rd Wire From The Connector To The Fuse Panel For Fuse #4 Due To Melting.
I Was Driving The Other Night, My Dash Lights Went Out, Followed By The Running Lights, Shortly After I Smelled The Smoke...Long Story Short, Typical Headlight Switch/Connector Failure. I Found Fuse #4 To Be Blown, Ran The Melted Pnk/Rd Wire Back To The Switch Connector. Replaced Both Components, Re-Wired Failed Wires, Installed New Fuse In #4, & As Soon As I Pull Out The Light Switch, POP! Goes #4.
It's Definitely A Short Issue, But No Sure Where? I Have Pinned & Ohmned Only To Fine The Blk/Ylw That Runs Every Single Light To Be Giving My Continuity (Beep Mode) On Everything I Touch. If I Probe The Blk/Ylw, Then Stick The Other Probe To Anything On The Fuse Panel, Even Hot Wires, It Beeps. The Previous Owner Installed A Toggle Switch For Rear Light Cut Off (So He Could Thank The Big Riggers For Letting Him Change Lanes Cuz He Was Sooo Cool) & In Doing So, Cut The Blk/Ylw In Half, & Wired In The Switch Between The 2 Pieces. I Can Remove The Toggle Switch Wires Completely, Having 2 Separate Pieces Of Blk/Ylw, Probe The 2, & It Still Beeps w/o Them Being Connected....
I Have Cut Harness Wrapping, Traced Wires, Jumped Wires, Replaced Wires, & Have A Pile Of Factory Tape In The Floor To Show For It, Only To Have #4 Still Pop When The Lights Are On For About 3 Seconds.
Any Help Would Greatly Be Appreciated, As Wiring Is My Achilles Heal, Just As It Seems To Have Been Dodge's.
