cougar wrote:What I need is the electronic schematic for the ecm/pcm itself. I need to know what's "in the box". I put in my spare ecm and only a marginal improvement. It's not freaking out anymore. Here is what is going on. If I adjust the TPS for 1 volt at idle OD will not shift in, but cruise control works fine. If I crank the TPS way down until it is off the throttle it shifts into OD just fine, but the cruise control runs away. Right now I have it set at the best compromise I can get, a slight letup on the throttle drops it into OD without it being too sensitive on a throttle up causing a down shift. I have been through every wire and connector even bypassing some to lower any odd resistance values.
