Does your ignition switch/tumbler area get super hot?
Postby Diesel » Wed Jun 26, 2013 3:03 pm
Man the metal on my ignition switch/tumbler get HOT! I am guessing good old Chrysler didn't use a relay somewhere and there is full battery current going through my switch?
1991.5 D250 Intercooled A518
Diesel
Re: Does your ignition switch/tumbler area get super hot?
Postby PToombs » Wed Jun 26, 2013 5:11 pm
Well, yeah! :lol: You may have something drawing more juice than it's supposed to, or the contacts are getting bad causing heat. You should look into it before you have at the least a small melt down or a fire under the dash.
Postby ellis93 » Wed Jun 26, 2013 7:11 pm
That's a dodge thing,you probably have a switch issue. Mine does the same,most all do
Postby Diesel » Wed Jun 26, 2013 7:28 pm
I would look into it but the switch should only be a trigger to the fuse box when running. It shouldn't be carrying full battery load but from the heat I've felt on the chrome part it obviously is carrying some amperage. I have noticed it for years but today I figured I'd see if you guys have felt it.
Diesel
