Just don't feel like searching and reading
Postby RCCUMMINS89 » Thu Jul 04, 2013 10:22 am
Can someone give me an easy step by step to by pass the cps and computer crap in the charging system.
Pretty sure my cps just crapped out and I'm not paying $122 that Napa wants.
What regulator do I put where? :lol:
Re: Just don't feel like searching and reading
Postby rockbuggy4x4 » Thu Jul 04, 2013 11:04 am
I have a voltage regulator on my '89. Its screwed to the firewall.
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Postby ellis93 » Thu Jul 04, 2013 11:30 am
Eric look in the last page or so in my 82 build tread,there's a self exciting reg that I'm using on a dodge alt. The part numbers there,and if you have a rebuild shop close they can get it.....you may be able to as well but idk. With all the hell folks go through with the dodge crap I don't think I'd put myself thru that if I could help it.
Postby RCCUMMINS89 » Thu Jul 04, 2013 11:55 am
How do I wire it up? Where do I put it?
I feel so dumb, but it is what it is.........LOL
Postby RCCUMMINS89 » Thu Jul 04, 2013 12:38 pm
Do I put it in line on the green wire? Meaning if I ran a wire from the battery to a regulator and then from the regulator to post that the green wire is on, is that how it's done?
My green wire, that's supposed to have 7 volts or whatever that changes with how charged the battery is............that thing just jumps all over the place from .1 to 18 volts in about a 10th of a second non stop.
Postby Mark Nixon » Thu Jul 04, 2013 1:19 pm
If you have an OEM regulator plug, Blue is "hot", Green is switching ground.
Green runs from the regulator straight to one of the alternator brush terminals, the blue wire ties into switched power AND the other alternator brush terminal.
If you want to call me at 402-780-5127, I can clear the air on the wiring.
I want to ask you some technical injection questions anyway.
Postby RCCUMMINS89 » Thu Jul 04, 2013 1:22 pm
I will call you Mark.........
However, LOL............today is me and the wife's 3rd Anniversary and we are leaving tomorrow to AZ. So I won't be able to call you until next Friday or Saturday...........which is when I need to fix the truck anyways.
I'll write your number down so you can edit it off if you feel need be.
Postby Mark Nixon » Thu Jul 04, 2013 1:33 pm
My number is for public use, with caller ID I can usually tell an idiot call from a real one. :D
As far as the info I need, I'll probably figure it out by then. :lol:
Postby RCCUMMINS89 » Thu Jul 04, 2013 1:36 pm
ok im making time
Postby ellis93 » Thu Jul 04, 2013 1:43 pm
RCCUMMINS89 wrote:How do I wire it up? Where do I put it?
There are detailed pics in my tread,plus I can help by telling you where to put the wire thingies :lol:
Postby RCCUMMINS89 » Thu Jul 04, 2013 3:10 pm
Ok............... I'll be fixing this thing next weekend............. so I'll post back, LOL
Postby RCCUMMINS89 » Thu Jul 04, 2013 3:24 pm
WTH?
Just went out to move the truck and now it's charging?
Postby BC847 » Thu Jul 04, 2013 4:25 pm
RCCUMMINS89 wrote:Can someone give me an easy step by step to by pass the cps and computer crap in the charging system.
Daggum! When it rains at your house, it pours. :shock:
Postby RCCUMMINS89 » Thu Jul 04, 2013 4:55 pm
Oh, I know........it's ridiculous
Postby ellis93 » Thu Jul 04, 2013 5:25 pm
RCCUMMINS89 wrote:WTH?
Bad brush most likely
