Right blinker dash light is on
Postby RCCUMMINS89 » Sun Aug 11, 2013 7:55 pm
Ok..............
When I turn on the headlights, the right blinker light on the dash comes on. Outside of the truck everything is normal. My blinker operates normally. My hazards, only the left hazard operates (both worked prior).
Now the funky stuff........If I'm in gear and accelerate the light goes off. In neutral and I rev it up with the same pedal spot, it stays on.
WTF
Re: Right blinker dash light is on
Postby ellis93 » Mon Aug 12, 2013 3:29 am
You've a corroded light socket,bulb,orground issue. You're 100% positive that "every" bulb works..... :D
Postby RCCUMMINS89 » Mon Aug 12, 2013 7:03 am
I'll double check that today.
Postby PToombs » Mon Aug 12, 2013 5:07 pm
Bad ground on a parking light on the right side. ;)
Postby RCCUMMINS89 » Mon Aug 12, 2013 5:20 pm
I think pete's on.
I didn't have time to confirm today, but I noticed that my air filter had smashed the blinker wiring harness at the connector. I lifted the filter up, went back in the dash and the light was off. Later I fixed the air filter issue, but the light was on after. But, I'm sure that's the problem.
Postby RumbleFish » Mon Aug 12, 2013 7:07 pm
Grounds do weird stuff. The builder of my crew cab ran everything under the dash to the same crappy little ground. The radio display would flash with the turn signals and it would shut off altogether when I used the pacbrake.
Postby RCCUMMINS89 » Mon Aug 19, 2013 11:47 am
Oh, to add to this post for the future on lookers and searchers.
Pulled the right blinker out and bam.............ground broken off of the light socket.
Postby ellis93 » Mon Aug 19, 2013 12:23 pm
ellis93 wrote:You've a corroded light socket,bulb,orground issue. You're 100% positive that "every" bulb works..... :D
Oh :lol:
Postby PToombs » Mon Aug 19, 2013 5:21 pm
Toldja so! :lol:
