rewiring pryo,boost,fuel pressure gauges
Postby jmd4993 » Tue Nov 05, 2013 11:56 am
i have to rewire my gauges because i did a getrag swap and the clutch master cylinder uses up the grommet whole on the firewall my wires were originally put through. when i was first doing my wires they said to daisy chain them together on the power, ground, and dimmer wire to save space. so i did this with splicing caps but for some reason the power wasnt transferred through the splicing caps in some areas. i had to use individual power wires for some gauges and ground wires as well which doesnt make sense to me. im pretty new at the electrical stuff.
i was wondering if you have to have a bigger gauge wire to splice from so there enough power to go around for all the other wires.
any information is greatly appreciated thanks a lot
jmd4993
Re: rewiring pryo,boost,fuel pressure gauges
Postby directinjktn1stgen » Tue Nov 05, 2013 5:25 pm
Can you be more specific as 2 which gauges did and didnt work ?
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Postby jmd4993 » Tue Nov 05, 2013 5:35 pm
they all work now but i what i really want to know is why the slicing caps didnt work really. i read its because the main wire need to be a bigger gauge than the trailing wires cause when you go to a smaller gauge wire apparently theres more resistance which will hurt the current flow.
i was just wondering if there was a another way to daisy chain the wires to make it a more compact setup thats all.
jmd4993
Postby jmd4993 » Tue Nov 05, 2013 5:36 pm
i like your all black paint job btw is that rattle can or no?
jmd4993
Postby directinjktn1stgen » Wed Nov 06, 2013 4:50 pm
:thumleft: It is john deere blitz black i sprayed it, for the first time ever trying
Correct it will! Unfortunately no thats probably the most compact way of doing is the right way! If you dont crimp them good enough or if the splice is to big for the wire is the only problems ive ever seen with them. I personally like solder and shrink wrap :thumleft:
Jeffery
directinjktn1stgen
Postby jmd4993 » Wed Nov 06, 2013 5:28 pm
with your own spray gun? i was thinking of trying to get a compressor and gun but i think the guy down the street might let me use his. its just crazy what a good paint job costs. but i dont want anything crazy just green on the top half above the trim and then be liner on the bottom half.
the solder is a good idea i just got a mini torch and solder cam with it. do you just lay the wires on top of each other then melt solder on to it. you dont need flux for that right? and i just got introduced to shrink wrap. its so awesome and easy. i just read that the crimps ive been using were the worst ones and to get weatherproof ones with the shrink coating on them.
jmd4993
Postby directinjktn1stgen » Wed Nov 06, 2013 5:49 pm
Yes I thought id try my hand at it so i bought it and its alright its a practice learning thing. flux is better but i just place the two ends toghter and twist to interlock the strands. then i heat from the bottom since heat rises and push the solder from the top.
Jeffery
directinjktn1stgen
