key wont go into ignition
Postby jmd4993 » Mon Dec 30, 2013 3:07 pm
my ignition was able to start the truck without the key for a long time and i was rushing to the store and didn't bring my key and of course when i went home the ignition wouldnt turn. so i bypassed it by hooking a wire to my lift pump and then one to the starter.
one thing was weird the truck wouldnt accelerate over 30 or so unless i was going down hill.
now when i go home the key wouldnt go into the ignition which has never happened.
any info would be greatly appreciated.
jmd4993
Re: key wont go into ignition
Postby dazedandconfused » Mon Dec 30, 2013 3:19 pm
Sounds like you need a new ignition switch. Did you happen to put 12v to the fuel shutoff? If not I'm surprised it ran but that will explain the lack of power
Postby jmd4993 » Mon Dec 30, 2013 3:30 pm
my fuel shutofff switch isnt working i have to manually shut the truck off. do you know how to replace one of those.
jmd4993
Postby dazedandconfused » Mon Dec 30, 2013 3:41 pm
Sounds like you have a nicked plunger since it wasn't killing the truck but limiting fuel. They aren't the easiest to get out from what I've read. I'm sure someone else who has changed one will chime in soon.
Postby jmd4993 » Mon Dec 30, 2013 4:18 pm
what about the key not going in the ignition is there anything to try before i buy a new one?
jmd4993
Postby dazedandconfused » Mon Dec 30, 2013 4:29 pm
Nothing I can think of off the top of my head.
Postby PToombs » Mon Dec 30, 2013 5:53 pm
Shut off solenoid is easy; cut, bend /break the bracket bolted to the pump head at the top of the head, then use a 15/16 wrench to screw it out. You may not get the wrench on if it's in the wrong spot, some people have used a hammer and chisel to get it loose. Remove the solenoid, remove the plunger (watch the spring in it) and put in the new one.
Postby the.beard » Tue Dec 31, 2013 8:23 pm
jmd4993 wrote:what about the key not going in the ignition is there anything to try before i buy a new one?
Yeah, I've had that happen on several old Dodge trucks. Look into the keyhole, it'll become apparent what happened. You just need to turn the outer ignition ring until the slot lines back up with the tumbler slot. Easy peasy.
1991.5 W250 Standard Cab, Long Bed. BONE STOCK (except for the dents; installed those myself)
"America is all about speed. Hot, nasty, badass speed." ~Eleanor Roosevelt
the.beard
Postby jmd4993 » Sat Jan 04, 2014 9:58 am
no the holes are lined up just wont go in. how to do you replace the cylinder. theres these weird star head screws. its a star with a round pin in the middle so none of my bits will work can you even get that bit in a store never seen anything like it.
jmd4993
Postby CumminsPower59 » Sat Jan 04, 2014 10:16 am
Those are tamper proof torx, either T20 or T25...
Postby jmd4993 » Sat Jan 04, 2014 11:51 am
i was told you have to turn the key to the on position to take the ignition out but the key wont go into the go all the way to turn it. what else can i do?
jmd4993
Postby DodgeFreak » Sat Jan 04, 2014 2:50 pm
Drill it out..
Postby dazedandconfused » Sat Jan 04, 2014 7:11 pm
