1990 cruise control
1990 cruise control
Postby 89dudney » Thu Feb 06, 2014 9:22 am
Did the 1990 model trucks have cruise control? If no, can one add the cruise control servo without the computer?
I like my truck more than I like 99.9 percent of people...
89dudney
Re: 1990 cruise control
Postby CumminsPower59 » Thu Feb 06, 2014 5:03 pm
As far as I know they did. Most of the wiring you probably already have. Why would you need a computer? My 91 had cruise, it should be just like yours...plug and play.
Postby TheSilverBullet » Thu Feb 06, 2014 7:01 pm
My 90 is an LE model and it doesn't have cruise :scratch:
Brownie-1990 w250 straight six standard transmission 445k odometer quit in 02 lol
The Silver Bullet-1998 qcsb 12v twins and a 6 speed
Blue bear- 2001 3500 pee pumped 24
TheSilverBullet
Postby CumminsPower59 » Thu Feb 06, 2014 9:20 pm
Just options my friends ;) Not all LE packaged trucks got every option, we all know that these trucks can be oddballs. IIRC, the 89's had the cruise switches on the multi function switch, i.e., turn signal lever. 90's had them on the steering wheel, as they are the "two spoke model" with the Chrysler symbol in the center. That is how my 91 was. 92/93 LE's got the "three spoke model" on the LE's and a mix of two and three's on the non LE's. Maybe Pete will chime in, as he put cruise control in his.
Postby PToombs » Fri Feb 07, 2014 6:28 pm
What I did won't help Daniel, mine runs off the PCM. I'm pretty sure that the older trucks with cruise had a brainbox someplace. I do know that the only thing different with parts for diesels vs gas is the cruise cable has a different end, and the servo mounting bracket is different. So if he goes to a junkyard and fins a gasser with cruise, he can get most of the parts.
Daniel, don't forget your dad's close personal friend, Mark Nixon. I think his number is #2 on your dads speed dial, #1 is voicemail and your mom is #3. :lol:
Postby CumminsPower59 » Fri Feb 07, 2014 6:49 pm
I forgot about ol Mark...
Postby PToombs » Sat Feb 08, 2014 7:16 pm
Most people would like to....... :mrgreen:
Postby tim curran » Sun Feb 09, 2014 6:29 pm
My cruise runs off vacuum. Not much technology involved there
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Postby PToombs » Mon Feb 10, 2014 6:18 pm
Tim, there's more to it than that. The vacuum only pulls the throttle on. There has to be a controller to open the valves to let vacuum in or out to control the speed. Your PCM controls the actuator.
Postby tim curran » Mon Feb 10, 2014 6:45 pm
True but this technology is not fancy its not smart cruise were an ecm tells all of these other things what to due. Its got relays that tell the vacuum solenoid what to due.
tim curran
Postby 89dudney » Wed Feb 12, 2014 7:23 am
So what exactly do i need to rob off a gas truck? I know where there is 3 or 4 gassers sitting that have cruise control.
89dudney
Postby KB-Cummins » Wed Feb 12, 2014 10:51 am
My 1990 has cruise and it has a dedicated module under the dash that is specific to 89 and 90 model year diesel trucks. After 90 they ran the cruise through the PCM. My module is in several pieces and I've been searching for a new one for a while. They can be a little tricky to find.
KB-Cummins
Postby CumminsPower59 » Wed Feb 12, 2014 12:48 pm
KB, I take it early 91 (NON-IC) trucks are going to be the same as the 89-90 as there is no PCM, correct?
Postby Tacoclaw » Wed Feb 12, 2014 1:49 pm
FWIW, I'm watching this like a hawk. I'm planning on attempting cruise on my RC, and I have a non-IC'd '91 that had the cruise setup under the hood and no PCM. However, it all got yanked, so hopefully we can piece it all together.
You got a pic/location of that dedicated module, KB? I've got the dash out of the '91 so I can trace wires and whatnot for us if it's the same.
Postby CumminsPower59 » Wed Feb 12, 2014 5:12 pm
Levi, the factory module is about the size of a deck of cards, right by the hood release handle. I snapped a few pics for you all...
