RPM ???? what am I doing wrong
Postby hager » Mon Feb 17, 2014 1:36 pm
hello men .I have a problem.so I have a Isspo 3"3/8 tachometer Whiteface blue letters chrome bezel .
#1. I bought the harness that Geno's garage had .
#2. and used it with and without a filter.
#3. Hook it up to my original wiring harness underneath the dash to the colors that they said and to the colors that I read on a good post
I can't even get this thing to move.
the rpm tach is sitting on 3500 rpm all the time is there something wrong with my tachometer?
and what is fluid dampening?
hager
Re: RPM ???? what am I doing wrong
Postby DMan1198 » Mon Feb 17, 2014 1:40 pm
Fluid dampening helps stop the gauge from being shaken to death
Postby hager » Mon Feb 17, 2014 1:45 pm
Ok. it says not to hold upside down for dampening failure I hope I didn't ruin it.
hager
Postby dazedandconfused » Mon Feb 17, 2014 1:56 pm
It could be a bad crank sensor on the truck too if it won't read through the factory wireing.
Postby hager » Mon Feb 17, 2014 2:19 pm
I put my voltage meter to it and it does read some sporadic numbers and when I push the fuel accelerator lthey change.. so I'm getting something
what does the crank shaft position sensor control on these first gens anyway because there's no sign of it not working
hager
Postby BC847 » Mon Feb 17, 2014 2:57 pm
dazedandconfused wrote:It could be a bad crank sensor on the truck too if it won't read through the factory wireing.
If that were the case, his alternator wouldn't gin.
What model number ISSPRO gauge? (you would think Geno's would have said if the gauge was incompatible with the harness/Cummins-Dodge)
Check out this thread where I've got the FSM diagrams of that plug under the steering column . . . . http://www.dieseltruckresource.com/dev/ ... p?t=185725
FWIW: I installed the ISSPRO M/N: R5503 and ran the lines direct to the plug without having to use the ISSPRO harness (filter not required).
Postby hager » Mon Feb 17, 2014 3:24 pm
 actually I cannot find the receipt for it and there's nowhere on the gauge that says the number so I'm kind of doubting i that I bought this from Geno's but look it up online again and here's the numbers
EV 0-3500 RPM Programmable Tachometer Gauge - R5535M
Part Number: ISS-R5535M
hager
Postby hager » Mon Feb 17, 2014 3:28 pm
its been about 8 months since I bought it just got around to hook it up I bought it so maybe I just need to program this thing to the right specs
hager
Postby BC847 » Mon Feb 17, 2014 3:35 pm
