Any Ideas? Bypassing/Overiding the VSS Vehicle Speed Sensor.
Postby Fred Average » Wed Apr 16, 2014 4:22 pm
As some of you know,when this fails=no overdrive,which is "no fun" with a 4:10 rear end :(
Anyone know how to do this?
1992 D250 360 V8 2WD,automatic transmission is the application.
Is it just an issue of connecting the two wires together,make a jumper to bypass the switch or is there other electrical issues?
Thank You All for any help. :)
Fred Average
Re: Any Ideas? Bypassing/Overiding the VSS Vehicle Speed Sensor.
Postby JeffTheMarine » Tue Jun 10, 2014 7:46 pm
I know a lot of people bypass the TPS and the VSS completely. Wiring the two control wires to just the on off switch. The only thing is that you have to manually control the overdrive coming on or off but I would personally prefer that myself. One wire should be a 12v power and the other coming off the trans should be a ground. All you have to do is to interrupt either one of the signals and that should be it.
Jeff
1981 Dodge W250 Crew W/94 12V&NV4500+NP205
Mods: Ground #100Plate,AFC Foot ground,BHAF
1990 Dodge D250 NonIC 12V Smoke screw flush,Fuel pin turned, Star wheel bottomed -5 clicks, fuel screw in 1 extra turn
JeffTheMarine
