CRUISE CONTROL
CRUISE CONTROL
Postby OLDEARL93 » Sun Nov 25, 2007 8:28 pm
ON MY 93 4X4 THE CRUISE IS NOT WORKING HAS ANYONE FOUND A SIMILAR PROBLEM AND IS IT SOMETHING SIMPLE OR IS IT REPLACEMENT TIME
OLDEARL93
Postby cummins king » Sun Nov 25, 2007 9:05 pm
my 93 4x4 curise comtrol didnt work, and it still dosent :lol:
93 4X4 auto
cummins king
Postby 2muchtq » Sun Nov 25, 2007 9:56 pm
Does the horn work?
If it works start chasing vacuum lines.
2muchtq
Postby cummins king » Mon Nov 26, 2007 6:06 am
no horn doesnt work ether
93 4X4 auto
cummins king
Postby GO OVRIT » Mon Nov 26, 2007 6:20 pm
Most likely the clock spring in the steering column. Chrysler still carries it. I want to say its $180+/-
GO OVRIT
Postby cummins king » Mon Nov 26, 2007 7:48 pm
thats okay i can do with out cruise
expecialy for that money
93 4X4 auto
cummins king
Postby PToombs » Mon Nov 26, 2007 7:54 pm
Check the crank sensor. If the PCM can't read that, cruise, A/C and some other stuff won't work. The wire plug gets corroded by the front of the head. Clearence to the crank should be .050.
Postby MMiller » Tue Nov 27, 2007 9:33 pm
The wires on mine failed where the steering column tilts. I took apart the column and found the bad wires, and my switches were worn. Instead of the $$$ for new parts, I wired in two toggle switches down under the dash. One for cruise on/off, and one for set. The only thing I don't have is resume. A three postition switch would get this.
I would look there before the clockspring. My horn has not worked in years. I drive a big 4x4, with a big winch bumper/grill gaurd, and dual straight pipes, I don't need no stinking horn..
Michael
MMiller
Michael
MMiller
Postby OLDEARL93 » Sun Mar 02, 2008 8:29 pm
IS THERE ANY OTHER THING THAT COULD BE WRONG WITH THE CRUIE ALL THE SUGESTIONS DID NOT PAN OUT IN THE DIAPHRAM BAD
93 4X4 EXTRA CAB 5 SP. GERT.EGT,BOOST ,RPM GAUGE,TIMMING AD,PUMP TWEEKED,NEW HX35,REST STOCK
OLDEARL93
