New vss and speedo still bounces all over.....
Postby Dan NJ » Tue Sep 09, 2014 6:53 pm
So while I'm driving it will bounce up to 50 then back down. What I have noticed if as I hit the throttle it will bounce up but when I let off it sits as 0.
Any advice would be appreciated guys
Dan NJ
Re: New vss and speedo still bounces all over.....
Postby ellis93 » Tue Sep 09, 2014 7:03 pm
Check your vss connection. Those barrel connector prongs can be loose and cause this.
Fwiw the sensors I buy (have bought) came with one.
Postby Dan NJ » Tue Sep 09, 2014 7:11 pm
Are you talking about the wires connecting it to the harness or plug? Cuz the wires I soldered in and shrink wrapped
Dan NJ
Postby ellis93 » Wed Sep 10, 2014 5:22 am
The plug for the sensor itself.
Postby CumminsPower59 » Wed Sep 10, 2014 6:11 am
Check the drive that the VSS goes into. Make sure stuff isn't all worn out, causing the drive for the VSS to slip and catch.
Postby Dan NJ » Wed Sep 10, 2014 8:44 am
CumminsPower59 wrote:Check the drive that the VSS goes into. Make sure stuff isn't all worn out, causing the drive for the VSS to slip and catch.
That's what I was kind of thinking , can I buy one of them new from anywhere?
The truck was auto and at the same exact time the trans blew the speedo dropped out, now I have a nv4500 in it with the original 23spline 205 (I built a 29/23 adapter). The odometer still clicks away no issue
Dan NJ
