Odometer not working but speedo does
Postby KTA » Sun Oct 26, 2014 1:02 pm
So I am still having problems with the electric speedometer in my crew cab swap. I put in a new set of gears and it still won't read. I get speedo action but nothing on the odo. There are 3 wires coming to the speedo is it possible the odo picks up from the RWAL sensor instead of the speedometer drive on the trans? I find it odd that I have two clusters and neither one works on the odo. That would suck if the circuit boards were bad in both of them.
Re: Odometer not working but speedo does
Postby KTA » Mon Oct 27, 2014 5:13 pm
Just for refrence for people if you have a reading speedo your odometer should work too. if it doesn't the problem is in the odometer somewhere. I took the one out of my 318000+mile service truck and swapped it in my crew and now it works. Apparently I had a bad circuit board/motor in my other one. Now I can check the fuel mileage with my 4.56's just for kicks before I swap to the 3.07's. My estimate from last weeks driving knowing where I had been was 16mpg so I am curious to see how close I am. That old 360 pig couldn't average 10 so at least it is an improvement! I really want 20mpg though!
