temp gauge testing
temp gauge testing
Postby Jl0696 » Sat Nov 01, 2014 7:40 am
92 w250 temp gauge not operating just sits all the way to the left. how would i test the sensor and wiring before i spend 70 on a new sensor?
Jl0696
Re: temp gauge testing
Postby ellis93 » Sat Nov 01, 2014 1:48 pm
I don't remember what mine was like but if it's one wire that goes to it,ground it against the head and have someone eyeball the gauge. It should set on the H when the wire is grounded.
Postby CumminsPower59 » Mon Nov 03, 2014 1:53 pm
ellis93 wrote:I don't remember what mine was like but if it's one wire that goes to it,ground it against the head and have someone eyeball the gauge. It should set on the H when the wire is grounded.
Correct. It is just a one wire connection. The coolant temp sending unit is on the rear of the cylinder head, drivers side, darn near up against the firewall. Make sure to get a good ground when testing, as the head, sending unit and the wire can get pretty crummy being back there.
Postby Jl0696 » Sun Nov 09, 2014 11:29 am
yep grounded out the wire and it reads H so my temp sensor must be bad guess ill order a new one today
Jl0696
