No blower on def or heat.
Postby TRACTJDS0428 » Wed Nov 19, 2014 6:13 pm
Blower quit working last year. No blower on defrost or heat on the floor. Works fine on vent and AC settings.
Any of you guys seen this or know it?
1993 Dodge W250, Cold Air, Borg Warner 60/68 turbo. 4" down pipe. 5x14 Injectors. Pump Mods. Airdogg II 165, Billet Fuel Tank Sump. ATS valve body, ATS converter, Pyro, Fuel pressure, Boost and Trany temp gauges. 72" T-Rex Products Long Bars. 285/75-16 Toyo Open Country M/T's. Western 9Ft MVP Ultra Mount V-Plow.
TRACTJDS0428
Re: No blower on def or heat.
Postby ellis93 » Wed Nov 19, 2014 6:46 pm
Probably the control panel. Or a poor connection in the wiring to it.
Postby TRACTJDS0428 » Fri Nov 21, 2014 6:13 pm
Thats kinda what ive been told. Any luck fixing it or just replace it?
TRACTJDS0428
Postby ellis93 » Fri Nov 21, 2014 6:33 pm
Don't know,haven't seen it. You'll just have to drag it out of the dash and look at it to see if there's anything burnt. Dpucket on here had a similar experience and he wound up replacing the panel.
Postby Firstgen11 » Tue Dec 30, 2014 9:04 pm
Ok man I'll try and pull it this weekend and inspect it lol
Firstgen11
