Ignition switch
Ignition switch
Postby 89BART » Mon Dec 15, 2014 5:34 pm
My trucks key turn ignition has hit the fritz and I'm having a hard time dismantling the pastic surrounding to remove the old and replace with the new. The truck is a manual and non tilt wheel so it should be easy. I'm just to the point of wondering if I need to take off the steering wheel. Any and all input is appreciated.
89BART
Re: Ignition switch
Postby PToombs » Mon Dec 15, 2014 6:17 pm
There are torx bits up in the plastic from the bottom. 3 in the recessed holes hold the top and bottom together, and the 1 silver one holds the bottom plastic to the column itself. There are tabs also, so after you remove the screws, you need to wiggle it to separate the 2 halves.
Re: Ignition switch
Postby 89BART » Mon Dec 15, 2014 6:28 pm
Thanks it was getting dark when I was working on it. I'll check it out tomorrow.
89BART
Re: Ignition switch
Postby cougar » Tue Dec 23, 2014 10:50 am
What year is your truck?
88-90 have the switch on the column under the dash. 91-93 it is up top with the key. Different switches and different R&R procedures.
01 2500 "the work truck".
cougar
