Common grounding or other reason for gauges misbehaving?
Postby 888 » Tue Nov 03, 2015 6:54 am
I'm headed down to Tennessee soon to pick up a 92 D350 5 speed truck and drive it back to SW ohio. My wife's cousin lives nearby and works for a repair shop so he gave it a test drive and a once over for me already. It's 5 hours home including a trip over Jellico on 75 on the Tennessee/Kentucky border and other than the fuel gauge (I believe), the gauges are randomly working or not working. For example, the oil pressure gauge works occasionally. Is there anything in particular to look at that would cause this, something like a common ground for the instrument panel? The light on the dash when the door is open works okay, for whatever that is worth. I'd sure rather have gauges for the drive home, going over that mountain. Seems that I've always had to replace the oil pressure sending unit in every truck I've owned but all the gauges are acting up.
thanks in advance.
Joe
93 Dodge D-350 Cummins Xcab DRW - completely stock
89 Dodge D-250 Cummins SRW 5 speed father and son project
84 Dodge D-100 5 speed slant 6
92 Dodge D-350 Cummins DRW 5 speed
others....
888
Re: Common grounding or other reason for gauges misbehaving?
Postby RumbleFish » Tue Nov 03, 2015 2:11 pm
I once drove to atlanta and back to pick up a w100 and had nothing but gps. Live on the edge man!!
Postby CumminsPower59 » Thu Nov 05, 2015 11:17 am
I'd say pull the cluster out and look at the condition of the plugs on the back side. Make sure the ground is good, and the printed board is ok.
