Differences tween 89-91.5 vs 91.5-93 wiring harness
Postby 2uphill » Mon Jul 01, 2019 10:46 am
Picked up another crew cab (82) and want to upgrade with Cummins and am wanting to update 82 with 1st gen pcs. parts to be same ( heater/AC, ECM, etc.,etc.). That way I only need to trouble shoot one animal if and when issues come up. I know I will need to swap column and a few things, but need to know if any advantage (and disadvantages) intercooled wiring vs non intercooled. I have donor trucks for both...hope this makes sense...thks in advance
90 d350, SRW, 2wd, 727, stock, except banks i/c, 85K
84 w350 crew cab, I/c 89, s300, 727, 4x4, 130K
90 w350cc, 3.54, getrag, 125K
82 d350 crew cab project
2uphill
Re: Differences tween 89-91.5 vs 91.5-93 wiring harness
Postby 2uphill » Mon Jul 01, 2019 4:56 pm
I assume (which has got me in trouble before) there’s not much difference, my 89 doesn’t have the ecm/pcm(?) module and my 92 does
2uphill
Postby cougar » Mon Jul 08, 2019 8:48 am
89 through 91 are the simplest. 91.5 is the same, just added TPS for A518 overdrive. 92 and 93 are more PCM dependent moving the voltage regulator onboard.
01 2500 "the work truck".
cougar
